alimac
Everything posted by alimac
  1. just tried this pipe and she LIVES ...but only with the choke out she runs out both cylinders once the choke is in she runs only on the left. could it be a spilt in the air intake boot?
  2. its never had one of those. i shall that out. carb bowls are the correct way round so il try this pipe and see what happens. thanks for help everyone. will let you as soon as i have done it
  3. this is interesting. its never had one of these pipes and its run before i put this kit on. i could of mixed them up i shall have a look later on today
  4. what does it do? its never had a hose between the 2 apart from the fuel pipes
  5. slides in correctly and moving freely, floats adjusted correctly, what little hose? the fuel line? could be full of shaving but i would of thought after 2 good cleans they would be clear? fuel is deffentaly in the bowl of the carb
  6. its almost if its not sucking it through from the carbs??
  7. tried that. wont start with any ammount of throttle. putting fuel in the left cylinder and with the choke on is the only way it starts. once running if when the choke is turned off it dies. but it is only running off the left side. iv stripped the carbs down again and cleaned everything again but still will not start
  8. hi there i have a 2002 banshee which is standard. i recently put an idler kit on my carbs, it now will not run. i have checked the compresson on both sides and both read good. Both sparks are sparking well, as they are new spark plugs. i have fuel to both carbs and is fresh fuel. i have also removed the carbs, taking the pilot jet, main jet and needle valve out and cleaning with a ultra sonic bath. Now the problem is that it will not run unless fuel is poured straight into the cylinder, even with this it will only run on the left side with the choke on, once choke is off quad stalls. any suggestions will be greatly appricated as it is getting very annoying
