Rhdguy88
Everything posted by Rhdguy88
  1. Can anyone figure this out
  2. Slides only go in 1 way because of guide stem correct?
  3. Would cut**
  4. Okay I'm a little stressed out about a situation I am having purchased 97 banshee Four weeks ago from out-of-state, brought it home in the issue I was told was an needed carburetor work. This is not the case I had the urge to pull the motor out, and when I remove the cylinders I found a detonated piston on the right side cylinder. Last week I redid the whole top end with new cylinders and 65.25 MM pistons. I took my carbs and dismantled them and let them soak over night in parts solvent. I have a 27.5 Pilot and a 280 main jet. I'm learning as I go but I am not new to engine rebuilding as I have worked on cars for years. When I first started the bike After the rebuild the right side cylinder was running perfectly while the left side woodcut in and out. After trying to fix it and running up and down the street to warm it up, the tables have turned and now the left is strong and the right is weak. As I am pressed for cash I would like some assistance on how to fix this or if anyone lives in Southern Connecticut and would be willing to give a hand I don't mind dishing out a few dollars for the assistance someone please help thank you.
