Sheeba711
Everything posted by Sheeba711
  1. Hard packed
  2. 350 for the spindle mounts 450 for the train traks need to get em gone
  3. Buy these parts up lots of good parts make offers also have a complete stock trans for 120
  4. Make some offers gonna start putting stuff on feebay this weekend
  5. DD 10x2 spindle mounts with asphault tires and brakes like new 400 81 inch rollout triple buffed 16 bar skat trak terrain traks on 9x10 blue labels 500
  6. Updated list Slingshot lockup 100 Srp throttle w/ extra levers 65 Cup topend 7 mil 900 Polished clutch cover 75 Chariot cages tdr epoxy 105 38mm flatslides with terry cable and filters 250 Straight cuts 250 barnett basket 75 Stock kicker very tight 50 Chariot bearing support for 530 sprockets 110 Temp gauge 30 Billet nuetral plate 10 Oem exhaust springs 10 Inner clutch hub like new 20 Plastics with seat 250 Drag tank 70 Modquad drag axle 425 Rear brake setup 100 Front brake set up with 7ft ss brake lines 105 Msr adjustable clutch perch with like new cable 35 530 alum honda style rear sprockets 44 45 46 30 a piece 530 banshee fronts 16 17 18 10 a piece Rear rotor 40 Flywheel 70
  7. Straight cuts back up for sale
  8. Straight cuts sold Barnett basket still available 100 Also adding 17 and 18 tooth 520 front sprocket 8 bucks a piece And 2 40 tooth rear banshee pattern 10 a piece See anything you like make an offer
  9. Also have 10x2 direct drive spindle mounts with asphault tires 400 40mm modquad drag axle with honda style sprocket hub 425 Rear brake setup with +12 ss line 115 Front brake setup with really long ss lines and a double bajo 125 Msr ez pull and cable 40 And the nitrous kit is back up for sale
  10. Id do 80 on the tank
  11. Crank stator coil sold
  12. The fuel tank is a 2 qt jr dragster tank brand is jaz and it has 3 petcocks
  13. Phone 7173316936
  14. Have motor torn down prices include shipping add fees or gift Rudy kurts 1 thru 5 modified drum last season for nuetral down 350 Complete 7 mil cub topend with arp studs acorn nuts 20cc domes cut by titan pretty fresh pistons as cast 900 Polished cover has some damage not bad though 85 Chariot billet cages with epoxy reeds 100 Reed spacers 10 Srp carbon fiber billet thump throttle some knicks 70 38 mm mikuni flatslids with k&n filters and terry cable 250 Straight cuts with barnett basket 350 Ekdr2 530 chain for a +12 75 Stator with pro design plate square plug 90 Slingshot lockup 100 Chariot bearing support with modified stator cover nut has been modded for a 530 sprocket 125 Stock kicker with upgraded parts very tight 60 Used fast clutch 30 good shape Temp gauge 40 Flywheel slight rattle 75 Billet nuetral plate 15 Cdi square plug 75 Coil 20 Like new oem exhaust springs 15 Like new inner hub 25 Cases with wack and stripped stator threads 70 Seat very nice 125 Plastics make offer
  15. Will get clean pics and price list this weekend until then make offers ... nitrous kit is sold
  16. Testing the waters .. up for sale is my 100 inch rigid turbo chassis bike with a 443 cub lots of goodies sb shearers 38mm mikunis straight cuts stock ratio billet basket chariot reed cages and tdr epoxy reeds n down 1 5 override small wet nitrous system set up for 40 hp right now fresh rebuild tz and maxload bearings chariot bearing support 530 ek chain direct drive spindle mounts and more any questions just hmu on here or by text 7173316936 looking to sell for new project may part out if I can move chassis and motor has ran 5.9 and 6.0 on 500 ft clay with 200lb rider gonna go with parting it out ill get a price list figured up this weekend also have extra 530 honda pattern rear sprockets and 530 banshee front
  17. Sorry bike is dirty in these pics it cleans up good ill get some clean pics this weekend
  18. Testing the waters .. up for sale is my 100 inch rigid turbo chassis bike with a 443 cub lots of goodies sb shearers 38mm mikunis straight cuts stock ratio billet basket chariot reed cages and tdr epoxy reeds n down 1 5 override small wet nitrous system set up for 40 hp right now fresh rebuild tz and maxload bearings chariot bearing support 530 ek chain direct drive spindle mounts and more any questions just hmu on here or by text 7173316936 looking to sell for new project 6500 $ may part out if I can move chassis and motor has ran 5.9 and 6.0 on 500 ft clay with 200lb rider
  19. Looking for a set of raw both out same side super cub pipes new or used Sent from my SCH-I500 using Tapatalk 2
  20. Ok will do thank you all Sent from my SCH-I500 using Tapatalk 2
