joewest
Everything posted by joewest
  1. Should my front and rear width be the same for my banshee to handle best? Or should the front or rear be wider?
  2. Wanting to get the front of my bike a little wider. I put +2 a-arms on. Are wheel spacers worth a shit? Are they safe? Should my front be the same width as my rear?
  3. I don't think so. If they did I would of gotten them Instead.
  4. Just waiting on my tie rod ends now
  5. I paid 390 new for mine on eBay. I ordered new tie rods. I fucked up my boots when I removed them
  6. Alright thanks
  7. I started installing mine today. Having hell getting the tie rod ends off tho. Any tips? Did u adjust everything how they say in the instructions with the straps etc?
  8. Anyone
  9. I'm installing +2 alba pro elite a-arms and I have to reuse my old tie rod ends and I cannot get them loose. Any ideas?
  10. What color is your frame? It looks badass
  11. Alright thanks
  12. I've adjusted it on the handle bars and it hasn't helped any. So you think my clutch is worn out? I don't think its slipping I run real close with my buddys kx250.
  13. Sometimes when I first start my banshee up I'll pull in the clutch and put it in gear and it will just pop into gear and die like the clutch isnt working. Sometimes it will do it a couple times then work fine.... just changed my trans oil it didn't help any.
  14. OK thanks guys
  15. Any suggestions to where I can get the best price on some cf1's?
  16. You can get both of them with bead locks. What do people dislike about hipers?
  17. Alright where is the cheapest place to pick up a set of hipers? Might just have to buy 1 or 2 at a time. Cheapest I've seen them is like 180 a piece. What is the difference between the cf1's and the tech 3's?
  18. 4psi is safe without bead locks?
  19. 18x10 r9. When I get new rims I'm gonna get either 9 or 10 inch wheels tho and run 20's instead of the 18's. All I do is trail ride and I get stuck every where and all they do is spin. 12psi might be the reason it spins tho....
  20. Lol when I got my banshee it had fuckin 28psi and would spin like crazy. Still spins a lot. So I could safely run 6psi in the rears? (Without bead locks) what should I run in the front ? Been looking at the hiper cf1's man there pricey tho. Looking at the it ss wheels also. They look heavy tho.
  21. I don't ride in the dunes. I pretty much just ride trails and fields. Should I get bead locks? Couple of my wheels are bent so I'll be getting a new set soon. What tire pressure should I run? I'm running 12 psi in all my tires currently.
  22. Figured out where the ball went. Where the hell does the little spring and o ring go tho lol. Didn't even have a spring or o ring come out....
  23. im rebuilding my kick starter and I pull it off and a ball bearing falls out. I have a new one but I cant figure out where the hell it goes!
  24. Alright I'll take it man. Pm me your PayPal info.
