jody breeze
Everything posted by jody breeze
  1. I need those cases, are there and cracks
  2. I've tried contacting Kelvin at herrsjugracing and no answer, its just the voicemail, I saw a block on their webpage I was interested in and a couple more things
  3. new to this dnt kno anything about pm
  4. Ok thanks will I need new circlips for the shifting rod I think that's what it is??
  5. Ok, after I get the case can I still reassemble the stock trans gears in new case or should I go bigger with gears, I will be riding trails and pavement roads, but mainly wanna smoke a raptor 700 without goning to a cub or cheetah
  6. I'm interested in cases and tranny
  7. Ok so I need to get both halves of the engine??
  8. Yea I was told that I only need the bottom have it was cracked on the lockup
  9. ok I think im gonna just pay extra and get the mechanic friend to reinstall everything lol, but thanks
  10. Ok thanks, now when assembling he parts onto the new/used bottom case is there, any kits I need to get when reinstalling the gears and parts from the cracked bottom case unto he new/used one??
  11. How hard is it to reassemble the bottom case back, trans, gears, and crankshaft?? I favorited a reassemble topic on here but all pics aren't showing
  12. Ok im new to banshee, where do I look to find one and what difference will it have on performance
  13. Ok and the 4 mil crank will be a good choice by wiseco
  14. I'm rebuilding my banshee and looking for the best pistons to go with .40 bore cylinders?? Also my banshee will be used on mostly back roads and some dirt trails, I've already went up a size (15t) on the front sprocket for more top end
  15. Yea you are right, but where can I find a good used engine
  16. I finally broke into my locked stock engine, the pistons were melted into the cylinders, the crankshaft was broke, and the bottom case was cracked from the crank, looking for suggestions on to rebuild or getting a good used engine???
  17. I finally broke into my locked stock engine, the pistons were melted into the cylinders, the crankshaft was broke, and the bottom case was cracked from the crank, looking for suggestions on to rebuild or getting a good used engine???
  18. Kmsl thanks tricked carbine, lol, I was thinking the same
  19. haven't gotten 1"yet, im new to banshees, so im getting everything together to have more top end power, and complete rebuild
  20. apologize for asking but what is STD??
  21. After replacing a stock crank with a wiseco crank and pistons, do u get the head cut??
  22. How do I do that, can I do it myself?" what will I need??
