rdz367
About rdz367
  • Birthday 12/12/1981
  • Interests
    SAND DRAGS AND DUNING
    T5's, Agressive port, boost bottle, vforce 1 reeds, stock carbs, 360 main jets, upgraded stater, lightened frywheel, 160psi both sides
rdz367's Achievements
  1. Pasi S. Thanks anything helps,im at 160 mains and 42 pilots, but very boggy no power band
  2. 1) What type of aftermarket exhaust do you have? T5 2) What type of airfilter do you have? K&N PODS 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all K&N PODS^ 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 140 ABOVE 5) What size pilot jets are you using? UNKNOWN 6) What size main jets are you using? UNKNOWN 7) What temperature is your Banshee jetted for? 80 TO 100 8) Do you have a port job? MILD DRAG PORT 9) What kind of carbs? KEIHIN PWK 10) What size carbs? 33MM
  3. hp2000 t5 pipes and mild drag port
  4. I have stock stroke, stock bore, 160 psi both sides, 33pwk, cool head 20 domes, 14 front and 44 rear sprockets, sea level riding temps 80-100 degrees F. need a starting point for jetting please help
