K&T Performance
HQ Site Sponsor!
Everything posted by K&T Performance
  1. K&T ran it once. About 300hp. Comes with Billet cases, Billet crank, Cylinders, Heads, Reeds, Intakes, Pistons & Big 48/50 carbs. Priced to sale. $8500.
  2. Cylinders ported by Randy Muchmore. Cylinders are Plated. Piston kit. Hardware Kit. Base gasket. $1300.
  3. Cub cylinders come plated from CP.. We port them to what the customer wants.
  4. K&T has 1-5 w/neutral down Banshee transmissions. $395 plus good core. Outright $595.
  5. They work great. Easy to work with.
  6. http://www.facebook.com/KtPerformance
  7. Stock stroke to 10mm stroker. Cylinders are unported & plated. $875.
  8. Cylinders comes with clear up portwork. Drag ported is extra. Cylinders are Plated. Piston kit. Hardware Kit. Base gasket. $1300. With Hot Rod 4mm Cranks. $1800.
  9. Randy Muchmore will do the case work too. Cubs $300. Want bigger transfers like Cheetah cylinders. $400. DM $600. DMX $750. Case work to match cylinders. Cubs $70. Bigger transfers $95. DM $475. DMX $550. DMX plate not included. Trenching for stroker cranks. $175.
  10. Prices are awesome at K&T. Randy Muchmore will do the portwork for you.
  11. K&T Turbo Kit for the Polaris 2008 to 2011 RZR XP 900. No cutting, drilling, cutting or welding required!!!!! Mounts to factory bolt locations. Includes the following: Modified Garrett Turbocharger Internal Wastegate and Billet Bracket 304ss Downpipe with Polished Muffler 304ss Turbo Inlet Pipe Custom Sheetmetal Plenum w/ (2) additional high impedence injectors & integrated air/liquid intercooler Custom Sheetmetal Front Mount Auxilary Intercooler High Flow Intercooler Pump 4 Ply Silicone Couplers and Clamps Braided Stainless AN Oil Drain/Feed Lines 1/4" Steel Turbo Support Bracket Cannister Style Cold Air Intake Misc. Hardware, Hose and Clamps Factory Programmed Fuel Controller with calibrated base map and harness for controlling additional injectors Factory Calibrated Clutch Kit (HD springs, turbo helix, and custom weights) YOUR PRICE FOR THE TURBO KIT IS $5600.00 CALL K&T FOR QUESTIONS OR TO ORDER THIS KIT. MONDAY TO FRIDAY 8am to 5pm Mountain Time. 801-825-5870
  12. The cylinders come ported by Randy Muchmore. One of the best in the world. His work has many recorders around the world. Banshee cases & 4mm Hot Rod crank not included. Stock cases will need to be setup to use the DM cylinders. Stock case work for DM cylinders will cost $475.00 K&T Full Drag Ported & Plated. DM Head w/Domes. Wiseco 78mm Piston Kits w/rings, pins & circlips. (10467MO7800) V-Force 3 Reeds w/Reed Adaptors. K&T Billet Intakes Manifolds. Cometic DM Base Gasket. Complete DM O-Ring Kit. Billet Exhaust Manifold. All Hardware. (studs, nuts) Priced for $2650.00A Call K&T PERFORMANCE at 801-825-5870 MONDAY TO FRIDAY 8am to 5pm Mountain Time.
  13. K&T has the Banshee Aluminum Drag Axles on Sale for $725.00 Made from 7075 Billet. They come complete with the Sprocket Hub, Disc Brake Hub, Locknuts and Wheel Hubs. You have a choice of Honda 4 bolt or Banshee 6 bolt sprocket. The whole setup weighs only 9.72 lbs. Yamaha's must use the oversize 40mm carrier. Aluminum Axles do not have any warranty from Lone Star Racing. Call K&T Performance. MONDAY TO FRIDAY 8am to 5pm Mountain Time. 801-825-5870
  14. Many of K&T Performance customers are 8th mile, 1/4 mile & street racers. Kim & Rayce Muchmore did many years racing 1/4 mile drag racing at local dragstrip. Kim ran drag cars to front motor dragsters. Rayce had a drag car. Plus K&T got a invite to drag race in front 8000+ spectators in July at Rolling Thunder dragstrip in Iowa.
  15. Any stroke DM cylinders. 78mm bore. Starting at 4mm up to 22mm stroke. Can have them ported by the best. Randy Muchmore. $600. If use stock Banshee cases. Cases will need work to use the DM cylinder. $475. Over a 4mm crank. Cases will need to be trenched. $175. Call for prices & questions. 801.825.5870 Monday to Friday 9am to 5pm Closed Saturday & Sunday
  16. K&T will have billet 120mm rods. The billet rods will have thicker on small & big ends. Making the rods very strong. Call K&T for info & to order the rods. 801.825.5870 Monday to Friday 9am to 5pm Closed Saturday & Sunday
  17. Crank Works 10mm Billet Banshee cranks with 115mm rods. Comes with TZ & Maxload bearings. $1200 Call K&T Performance. 801.825.5870 Monday to Friday 9am to 5pm Closed Saturday & Sunday
  18. 10mm DM topend kits w/10mm billet crank w/115 rods. $3750.00 Stock case work for DM cylinders. $475 Trenching for 10mm stroker crank. $155 Call K&T for questions & to order one for you. 801.825.5870 Monday to Friday 9am to 5pm Closed Saturday & Sunday
  19. K&T Performance has Shirts, Hoodies & Hats in stock on sell now. T-Shirts. $16 Med-XL XXL-XXXXL Hoodies. $25 Med-XL $ XXL-XXXL Hats. $15.00 S/M L/XL Call K&T 801-825-5870 Monday to Friday 9am to 5pm Closed Saturday & Sunday
  20. Comes w/all hardware. Awesome price. $250.00 unpolished. Call K&T to order. 801-825-5870
  21. Comes with all hardware. Unpolished. $210 Call K&T to order. 801-825-5870
  22. K&T has specials on Crank Works 10mm Billet Banshee cranks with 115mm rods. $1200 Call K&T Performance. 801.825.5870 Monday to Friday 9am to 5pm Closed Saturday & Sunday
