98_banshee
Everything posted by 98_banshee
  1. Yeah, the carbs are also in sync. I made sure they are. And another question. They are mikuni carbs but insted of having a round top they are square at the top. Why is this?
  2. well today i took apart my harness and found out one of my connections came loose so i plugged it back in. it was the white/red wire which runs from your cdi to your magneto. i then tried to kick the bike over and it still wont start. i know your not supposed to spray starting fluid in a 2 stroke but i sprayed a little in it anyway. it started up and ran for about 5 seconds. which now makes me think its a pilot jet clogged up or something clogged up inside the carb. anybody else have a input on the matter, any suggestions???????
  3. Alright thanks guys, I'll keep you guys posted with what's going on
  4. It's nothing wrong with the coil, I'm gonna put my keystart back on and see if I has to do with that. I think it has to do with the fly wheel gap and the key inside the flywheel. I'm gonna go figure her out and get back to y'all
  5. N2o that's what I did, and sheeeider if it was a bad cdi wouldn't the bike not start at all? And I'm leaning toward the stator. It has compression I also pulled the head and pistons look fine. Thanks for the help guys hope I get it figured out soon.
  6. I don't think so, I'm new to most of this two stroke stuff. I also heard it could be a bad crank case seal? I'm stumped I have no idea what to do.
  7. The other day I was letting my banshee idle and it was running fine and then the idle got really low and only the right cylinder was firing the left was blowing cool air out of the pipe. So I switched the plug wires and then the left cylinder started firing and the right was doing the same as the left before. I switched out my coil with an extra one I had and its doings the same. I tested the coil and it's getting spark. Brand new plugs in the bike. So today I took off the carbs and cleaned them. They were fine. It won't idle at all. Someone please help I'm getting really frustrated. Reeds are also fine. Only thing I could think of is a weak spark or something coming from the stator.
