slattmoan
Everything posted by slattmoan
  1. So I appartently jacked up a plug messing with it - New plugs and she runs great! Now I need to address the clutch......... While in 1st gear she tries to go even with the clutch pulled in all the way - Has done this for quite some time, but has steadily gotten worse. Any thoughts?
  2. Aright, I took the carb apart, and cleaned everything thoroughly - I am confident my fuel is flowing properly now, because i can definitely tell a difference when I look in the carb & the way she sounds. She starts on the first kick and will idle fine, but the crazy part is that the left muffler will begin to eat up normally while the right muffler stays cold to the touch. I am stumped...
  3. Just to clarify, I took the carbs apart & cleaned them, but I did not touch the jets or remove the floats. THANKS IN ADVANCE!
  4. Okay new info: I just pulled off the air filter, and started her up while looking into the carbs - I am not getting fuel blown up the carb on the right. I have already removed, torn down, completely cleaned, and re-installed both carbs since this problem started so I dont know what to do. Any idea as to what is malfunctioning in the carb?
  5. Yes. I checked for spark, swapped left & right, and even installed a new coil - Exact same response.
  6. Any of you have any luck with this? I have identical symptoms as the original post... Took this '04 Banshee out to Little Sahara Sand Dunes in NW Oklahoma that I found on Craigslist - Ran great all day Saturday & Sunday morning, but became sluggish around noon. Packed it in & returned home to rebuld the carburetors, new coil, new plugs, and new plug wires/caps. Starts up on first/second kick, but will not idle without some throttle. I can make it around the block by getting on the gas, but when I get back to the house the right exhaust is still cold to the touch while I wouldn't dare touch the left. The part that baffles me is that while riding the short distance around the block, there is a normal amount of smoke coming out of the left pipe, but the smoke on the right does not have any smoke most of the time - Very few intermittent puffs would come out when I got on the gas hard. I could feel light air pressure leaving the pipe when there wasn't any smoke - Not sure if that means anything or not. Thanks in advance...
