HAWAII-808-BaNsHee_BoYs
Everything posted by HAWAII-808-BaNsHee_BoYs
  1. You must be from kailua?
  2. Yeah buddy, if you race I probably know you... Yeah i'm coming out to win at KRP. I'm only going to race when my motor is completely done which should be in 3 weeks or so. I haven't raced yet but from what I see at kalaeloa no one will beat my motor unless they have one of the sponsors on here build the motor better then what i'm getting from wildcard and rdz. All the bikes at krp would have a hard time keeping up with the bikes in the mainland.
  3. What is the best oil to mix 110 octane and the ratio?
  4. What size rims should I use if i'm racing flat land sand drag?
  5. Okay thanks every1 for the input.
  6. So when i purge the bike i use 92 fuel and oil mix?
  7. Do I have to drain the gas tank after every ride when running methanol? What else do i have to clean the carbs after as well?
  8. I dont really know anything about race gas or any other. Ive only used 92 before. This is the first time for me. And yes im going to throw those domes away lol. thanks for the advice bigred.
  9. So what size domes should i use? i have the heads that came with the kit but im not sure what size domes to use. I want to run 110 race gas. What oil should i mix with it and the ratio.
  10. i got the kit from trinity racing, its the 485 cheetah kit. I dont have a timing plate but im going to buy 1 now.
  11. Im new to racing banshees and i have a 485 cheetah kit with power valves, 35mm carb, dynatek ignition with stage iv pipes and heads and domes. what size domes should i use if i want to run race gas and should i get a timing plate? What should i set the timing plate to if so? its kinda important for me because im going to race a raptor in a few weeks so please help me out. Also what type of oil should i mix with 110 race fuel and the ratio?
  12. Im building a sand drag motor through kevin at herr juggs racing its a 10mil 465cub drag ported. Im trying to beat a few guys that have trinity 421 and 485 cheetah motors and a raptor 800 any info on what i need?
