1995 350 Banshee
1995 350 Banshee's Achievements
  1. One carburator gives you more bottom end power like your hole shot but when your up to speed it doesn't have much power
  2. I had a 2 in 1 piece that my carburetor went to I didn't really like it. All it did was mostly make it cut out
  3. that didn't help anything.. Thanks for your (input)
  4. Is that what you run savage?
  5. wow thats kinda fucked up.. I Might try a might try a new filter as i just blowed this one out.
  6. i got k&n airfilter
  7. is yours not wanting to kick start either?? I have to push mine to get it start.
  8. i just had to put a new rear bearing carrier on my banshee
  9. Lrd pipes sorry bout that
  10. keihen single carburetor, racing pipes
  11. there 126 but yes pilot jet was plugged cleaned it and cleaned air filter. Would have anything to do to with plug wires or cdi box?
  12. won't start with kick start but will start if you push it. Checked compression both cylinders are good. Changed plugs. But every so often it will kick start. Any ideas?
  13. maybe the wires? or I was told the CDI Box..
  14. I have a 1995 350 Yamaha Banshee is not wanting to kick start but will pull start easily, Cleaned the lean pilot, The Carburetor, Put new Plugs in it, I checked the Compression today and both cylinders read 125 is that to low? cause that is the only thing I can think of that could be wrong with it.
