bike barter
    1991 banshee bored .30 over is all i know
bike barter's Achievements
  1. yeah i useds a torc wrench 7ft pounds and i dont have any play in the leaver when i pull the the clutch lever i can c the first 3 plates push out ??
  2. banshee keeps miss fireing in the right cylinder iv tryed new plugs new plug wires i even tryed switching the wires still miss fires i need help
  3. fuck my life as my banshee robs my wallet i need some clutch work
  4. i took it back apart the presher plate looks to be lined up when i pull the clutch lever in i can see olny the first 3-4 plates push out my clutch was working great untill i took it off to replace the the broken bolt for the shifter spring
  5. i took it back apart the presher plate looks to be lined up when i pull the clutch lever in i can see olny the first 3-4 plates push out my clutch was working great untill i took it off to replace the the broken bolt for the shifter spring
  6. i think i put the clutch on wrong i need help its all rev and no go
  7. thanks man im going to rip it down now
  8. i just got a 1991 banshee of corse it needs more work then what i was told i have a lot of slack in my shifter up and down and in the shift rod back and forth when the bike is running i cant down shift shifts up just fine with alot of play tho but when its off it will down shift but i have to play with it for a little bit can any one help me what should i do
