bustedknuckles
Everything posted by bustedknuckles
  1. Stroke says 54mm so yes
  2. Ok I bought the Athena 68mm kit about a month ago, I haven't had a chance to put the motor together yet. I was wondering what I would have to do to in order to get a 4mm crank to work with that set up.
  3. I had one on my yfz, if I put a cooler and a gallon can of fuel on it after a ride it would loosen or break the bolts in the mounts, I took it off gora blingstar grab bar and haven't fooled with it since
  4. im currently building my engine for my banshee...I have a hotrod crank(stock stroke), and the Athena top end kit. after I get that built im going to put in v-force 3 reeds and shearer inframe pipes. I am wondering which carbs would be the best selection for my build. I have two sets of stock carbs that came with the rolling chassis I bought, the question that I have is will they supply enough fuel or should I go ahead and buy bigger carbs, and which carbs would be the best for my application... thanks in advance
  5. is the carb still available?
  6. its a little late but i was there on my yfz, i live in gilbert so i go almost every year
