smyregregory21
Everything posted by smyregregory21
  1. I'm trying to make a banshee look just like it did in 1987 for some one. I need to know what color every thing was. Factory pictures would be great I can't seem to find many thanks guys
  2. Looking for -2 swing arm or -1 preferred -2 with carrier but open to options. let me know what u got
  3. Any one race mx in north Carolina
  4. Looking for nuts and bolts for bolting shock link to frame Long Carrier bolts to swing arm all shock bolts casel nutsvfor tie rods caliber bolts the nut for the fly wheel foot peg bolts chain tenshiner peaces i need the metal plates that go being the clutch basket the metal peace that oil the bearings with the screws that hold them in Looking for good front and rear white plastics red gastank and radiator plastics let me know what u have thanks guys
  5. Got all the parts i needed thank you guys for the help just need shifter shaft now
  6. I need kick starter the washes for the back side of clutch basket and between the clutch The half moon peace that hold the crank bearings in place Engine mount bolts
  7. I have bent a upper left arm mad by timmy boy designs and broke a lower ball joint any one know where i can get a replacement joint and a comparable replacement upper? thanks guys
  8. Ok guys thanks for the help ill get in touch had a wreck at mx need left front plus 2 plus 1 a arm set now so that's gonna be my main focus
  9. Boost too post in dier need for ball jointsvfor +2 +1 timmy boy arms
  10. I'm being hopeful some one wants a cheap set of pipes for some kinda cheap part I may need let me know what y'all got
  11. Dg pipes not shirty but nothing pretty text me for pics 828-381-1159 Wider then stock axle Good round house Carrier 2 into 1 carb set up Anti roll bar Idk throw sum thing at me
  12. Yes thank you for your help saved me a 40 mile round trip
  13. Hey I need to pick up taps to make my tie rods tomarrow and for got the old tie rods at the shop can any one tell me what size the tap would be for example ( M 10 1.25) any one know for sure thanks greg
  14. Kill switch teater 1 or 2 22cc domes prodesigns 1 cool head stud Swing arm bolt and nut Right side spindal Ss brake lines front and rear Let me know what u got
  15. smyregregory21
    headlights
    I have a white set with bulbs and grills only problem is grills fall off I use electric tape to hold them on and u can't really see a diffrace in the look. Pm me for pictures and price
  16. Here's what I did I started it up then starter cutting one wire at a time then when I figure out what was needed I put weather packs from Napa where I thought I wanted connections. Fast and painless way.
