Calaber07
Everything posted by Calaber07
  1. how to make leak
    1. BUILDER
      BUILDER
      Unzip your pants and pull it out that is how I make leak
  2. How much for headlights. Pictures? Sent from my iPhone using Tapatalk
  3. Am I able to switch the floats for left to right? Sounds like a stupid question tho. I should probably just go and and buy some carb rebuild kits right? Sent from my iPhone using Tapatalk
  4. Nevermind... Got it all the plastics back together and it's leaking again. Kicked her over and back to square 1. Pilot is clean now. Is it just flooding itself? Sent from my iPhone using Tapatalk
  5. Pulled them out cleaned them up. Pilot jet was deffinely clogged. Ran her up the road a few times and running like a champ. Thanks a lot for your help!!! Sent from my iPhone using Tapatalk
  6. It is quite irritating to tell you the truth. I hope I can get her running by tomorrow. Haven't got to drive it that much due to working 24/7 lol. I also want to get the tors eliminator kit soon aswell but I'm nervous as shit to drill and tap it for the idle screws. I appreciate all of everyone's help! Sent from my iPhone using Tapatalk
  7. Ok I will try that when I finish work tonight. Just went and picked up some carb cleaner this morning. should I blow air through it with my compressor.?Would it damage it.? Sent from my iPhone using Tapatalk
  8. Will do this weekend. But if it is not what is causing it what would? Runs fine no knocks no nothing. The only thimg that makes noise is my kick arm thats it. Maybe a broken reed? I'll inspect and switch those around while I'm at it and let you know. Sent from my iPhone using Tapatalk
  9. Maybe someone can help me out. Bought a 99 banshee 2 weeks ago. went out the other day to kick her over for a boot. Pulled the choke out half way and kicked her over. Both cylinders were running. Shut the choke off and revved her up a bit and both still running, walked away to get my gear on and walked back to find right exhaust not putting out any smoke. Tried revving or up some more and it started to backfire. Shut it off switched plug wires around same thing with the right not running. Changed plugs still the same. But when I pulled the choke back out half way there she goes running again lol. So I shut the choke off and took her for a 5 min boot and she runs when your on her. Got back to my garage to find a puddle of fuel on the ground that's flowing out of my overflow tube on my right carb. Bought a compression tester and both sides at 120psi. Help!!! Lol obviously my float is stuck. Is that causing this to happen. Also the owner prior to me had it 8 years and said he ran it 2 a year up at his cottage. Bike is mint condition, very well tAken care of. Sent from my iPhone using Tapatalk
