general shee
Everything posted by general shee
  1. the 2 stroke oil you mix in the gas is what lubes the crank + cylinders. then you have the transmission oil which is seperated from the crank and cylinders i use yamalube 10-40 better for clutches
  2. my was to hot all over because of a broken water pump gear yours sounds like everything is working properly i installed the mull pump and gear and now after ripping through all gears on the street for 20 mins then a 40 min hard ride through the trails pulled over and while it was still running i put my hand on the cluch cover on the top and it was warm but not hot
  3. so that's how that works
  4. got it figured out the plastic water pump gear broke so i put in the mull water pump and gear and now the clutch cover is at normal temp sorry it took so long to reply but i am not one to wait when my bike is hurting FIX IT FAST, FIX IT NOW, FIX IT RIGHTon another note i am new here and apperciate the help from the ones who can comprehend what i am saying THANKS, RACER X
  5. my clutch cover is getting very hot. does anyone know why? its too hot to touch.any help would be greatly appreciated.
  6. do you still have the axle?
