youngblood
    1999 yamaha banshee stock
youngblood's Achievements
  1. hey guys in the near future i plan on tearing apart my 1999 yamaha banshee and i would like to know which aftermarket carb is the most reliable or well built based on your expierence.. thanks
  2. put the choke tube back on and tapped the floats ... they swung free and it runs great ... thanks guys!!!
  3. yea they are stock carbs... any idea where i can get the tube? or an alternative
  4. i just took the carbs off again and there is no tube to be seen... i called my local powersports store and they said there is no such thing... i kept on pursing and he said to adjust the floats and look at the needle and seat
  5. thank you very much!!! i will look at choke tube didnt even check to see if it was fastened... the gas leaks out the overflow line but you can see that the bowl on the outside is covered with gas... today i just undid the 4 screws and took out the bowl.. i sprayed carb cleaner through it and either side of the carb and blew compressed air through it really good... put everything back... it still leaks gas and is now not idoling correctly it sounds like it sucking in air and all i can guess is that it might be the two missing bowl gaskets? or even the choke tube like you suggested
  6. update ... i ended up taking off the bowl to the carb and there was no gasket... could this be my problem? carb was clean inside
  7. the gas has been off ever since... should i take the carbs off when tapping the bowl or it doesnt matter?
  8. no at first i seperated it thinking i could get the carb off in an instant but i couldnt and then i put it back in
  9. Forgot to add, i removed the rear plastics and airbox and seperated the carb from the reed valve dont know if that helps
  10. Hey guys my names matt im 15 and last week i bought a 1999 yamaha banshee bonestock... It ran great for the first couple days, but when i put it away one night, the next morning a puddle of gas was underneath the quad i took a closer look and its the overflow tube from the left carb... Any help would be appreciated!!!
