tibo1988
    1999 Banshee Toomey t6 pipes and silencers, Jetted carb, V force reed cage and spacers, Aftermarket air filter, Pro taper handlebars, Amr racing graphic kit , Emergency brake block off kit , Recent re build , Aluminum racing rims , TORS removal kit
tibo1988's Achievements
  1. Hello my banshee is shooting a little water mix from the exhaust and running a little wierd. There's a smell of gas in the radiator also. No extra fluid in the gearbox. I'm thinking head gasket? Still starts right up and runs good the side that is shooting water is a little choppy but it still has compression.
  2. And I Do have an afrermarket spacer correct?
  3. Can anyone tell me what intake setup this is, and if this ignition is ok?
  4. Was just wondering other than cosmetics does this swingarm look wierd? Just looks off to me. I don't know if it is because there is no armor, or if the caliper is off?
  5. Hello, first post woo!!! Not new to wrenching, just to banshees. I have a 1999 Banshee. Runs pretty good little hesitation on one cylinder that smokes a little. I'm ready to fix that. Havn't dug into yet, at work for the next three days ughhhh. Unk if it is bored or ported yet but I'm gonna assume not. Po said it has a new tranny, crank, and clutch who knows but everything works. Starts right up and idles for about 30 seconds and dies, stays running if I want it to with a little gas. Has good compression when kicking. Revs up fine. The mods are as follows Toomey t6 pipes and silencers V force reeds and spacer No airbox lid/snorkel Tors removal with the idle screws Aftermarket filter I live in the Philadelphia area, I don't know what the jetting is now just wanted to know what I should have in there. Maybe help me with the hesitation, smoking and rough idle. Has new plugs gonna clean the carbs and sync. Please let me know needle clip, air screw, and main and pilot sizes.
