ernesto
Everything posted by ernesto
  1. thanks m67105 sounds logical , will try loosening the stud bolts thanks again
  2. hahaha just order yamaha oem cylinders , i can see in eBay auction for the NICHE cyl kit they have been sold 504 kits where are these all 504 units ???
  3. hi zillafreak please confirm if these NICHE garbage cylinder juggs fitted good on your banshee ? thanks erne
  4. studs are oem yamaha for banshee , they fit the hole the problem is they are not straight to the holes
  5. the real issue is that the upper cyl studs won't fit in the head cover holes , the only way to get the cover is by hammer and i don't want to do it in the past the head cover will fit by hand easily , with these new niche cyl the cover won't go easily
  6. first time i have issues with my banshee , i call NICHE customer service and they send me 2 new juggs i install them and same problem i thinks niche cyl are not perfect olds juggs goes in easily , with this niche are impossible to fit the head to the bolts they are far away from head holes can i hammer the studs to align them or prefer to get yamaha juggs ?
  7. thanks for reply i will try loosing the jugss to put on the head , studs are new
  8. hi i was rebuilding my banshee top end , and have some issues trying to fit the head cover got 2 niche eBay cylinder jugs 4 dowel guide ( 2 each cyl) oem 2 lower gasket oem new stock head cover oem new yamaha head studs oem 2 cyl seat rubber oem i install everything correct and when i try to put the head cover doesn't align with the stud bolts what could be wrong ? everything is oem yamaha except cyl juggs are NICHE thanks
  9. Thanks men i will change them back to stock ones and try , 3 # clip as stock ?
  10. hi i just try moving clip 1 up and it feels better now but still rich , but thanks for the help , im using vitto rebuild kit for banshee , i take a picture of the main needle i use to have and the one im using this moment the gold one ( short one) stock the silver one (long one) vittos kit , actual using why is longer ??? should i use the gold one ????
  11. Thanks my friend I will check it in the nite , so it should be good in the 4rth position
  12. Forgot to mention the rich is in the beginning then at half throttle it get fixed
  13. Thanks for the help , so I need to move the clip on the main needle I have it in the 3rd pos , stock Should I move it 1 lower or 1 upper??? Thanks
  14. hi i have a 2000 banshee with , tors eliminator , tommey 6 pipes , k n air filter , everything else stock . main jet 280 pilot 25 screw 1.5 turns i live in panama * sea level , the bike is running extreme rich , should i use 200 or 260 main jet ???? thanks
