rcourtnier
Everything posted by rcourtnier
  1. Are the cylinders still available? Pics??
  2. Yep I've had 25's, 27.5's, and 30's in for pilots. No leaking of fuel while it's just sitting there.
  3. Thanks. I tried this prior to moving needles up anymore. Put all settings back to stock no change. Did a leak down test just to see if there any leaks, held 6lbs. for 20 minutes. Compression seems low 135-140 with 17cc domes, checked pistons and jugs everything looks good. Completely cleaned carbs again?? Could it be Electrical, timing etc.??? Carb float needles not seating??? Seems like i can't get it to lean out with anything i do.
  4. Rebuilt my banshee after 5 years of sitting. New top end, Chariot head, dune porting, CPI pipes, reeds and stock carbs with K&N air pods. Went to Oregon Coast ran good with one little flat spot at 1/4 throttle. When i got back home i change pilot from 27.5 to a 25 and adjusted needles up 1 notch from stock. i am running a 310 main jet set up for sand mountain 4500'. My problem is it won't idle now and is running really rich. i have adjusted air screws to 3 turns out, idle screws all the way in, ran needles all the way to top notch, manually adjusted slides up with no air filters and this is the only way with push start to get it running and idle. Plugs are still wet. HELP! 32:1 fuel mix Thanks for the help in advance
