Banshee Dubstep
    2002 Toomey T3, .20 Bored Milled 21cc heads
Banshee Dubstep's Achievements
  1. When you remove the TORS can you remove all the wiring including the piece in the thumb throttle box? Can you just disconnect the parking brake plug too if you don't want to worry about that too?
  2. Okay thank you, I took apart my left TORS unit and it actually seems to be together and working it just wouldn't adjust the slide while it was connected
  3. So I just did a fresh top end rebuild on my banshee with .020 wiseco and the heads were milled to like 22cc and I have toomey t3. The carbs are jetted for the pipes do I don't think it's a jet issue. The engine will run fine but it just wot idle. I still have the TORS on it and I'm pretty sure my left one went out because the only way to move my left slide is from adjusting the top boot. I ordered a eliminator kit and it should be here in 3 days but I just wanted opinions on what could all cause it to not want to idle
