Mud_n_sans
Everything posted by Mud_n_sans
  1. Hello! So...I had a polished clutch cover and it cracked behind the kickstarter shaft where they are prone to split. Got some new covers and polished them and installed one on my banshee. Previously, I had a purchased a pro-design water pump cover/drain plate. Also I had on my old clutch cover a billet polished water pump cover. It appears that the drain screw must have been a tight fit before because the drain screw rubbed the inside of the cover. With my new clutch cover, if I put the three screws in the water pump cover and tighten them up there is a 1/8 gap all the way around after the cover meets the screw head. Because the cover is aluminum, i could force the gap closed by tightening the screws but I dont like the idea of doing that. I want to find a cover that clears the drain screw. I purchased a new cover that I was assured would clear the drain screw that turned out to be more shallow than the one I had. I asked all the local shops with no luck. I have had no luck with online retailers as they are all drop shippers. Can't get a hold of anyone at the manufacturers to get depth measurements. Does anyone else run a pro design ez drain plate? What water pump cover did you get to fit? What is the depth measurement? Please help me find a cover that clears the drain screw. Thanks!
