@thecribchillin
Everything posted by @thecribchillin
  1. To be honest I wanted to remove the both of them......so I guess it kinda works out. Where can I order the removal kit for the tors system, and is it hard to remove the both of them??!? The parking brake never worked, and when I flipped it it stopped moving so its pointless really.....get back to me, any tip helps! Thanks
  2. so i tried disconnecting the plug going to that black box for the TORS brain........still same thing. what i did was recorded a video of what the problem is, its a short video but it gets the point across. i was trying to describe the noise but its hard to explain in letters lol so here is the youtube link, take a look and listen to see if you notice anything or have an idea what it is......again thanks guys
  3. Thanks for the tip but that doesn't seem to make sense to me, parking break making my engine bog in neutral?
  4. So are you saying it could be a small turn of the screw on the side of the carbs?
  5. Yes I do have that annoying toors system on my bike still an I started to mess with the screw on it and found out that it only controls the throttle tension and made the bike jus idle higher and yes I still have the useless parking break . I would like them both removed eventually, could it have anything to do with the reeds??
  6. oh, it was kinda cold last time i rode it....not freezing...its now starting to warm up here in philly a little bit. but nothing drastic
  7. no the temp is fine, its not getting too hot or overheating........the noise sounds like a serious sucking noise thru the carb. thats the only way i can describe it
  8. so heres my problem for my banshee.......hopefully someone can help me out! i was riding thru the neighborhood the other day and everything was fine, no problems at all. i put it away and it sat there for a couple days, pulled it out after 3-4 days and started it up with one kick.....it idles fine and will stay running. the problem is when i give it gas, it wont shut off when i give it gas but its not reving high at all and it makes a crazy noise from the carbs in the airbox. its bogging down when i go to give it any type of acceleration in neutreal or in gear. i finally got it moving and it will only do 15mph TOPS.....someone help, im trying to ride this weekend!!!
