NickJames
    4mil, cheetah cub, 40mm pwk
NickJames's Achievements
  1. Banshee hill, sand mt., NV . 10- 15 seconds. I've been told that I should be fine without , but they all have different carbs, which tells me I need a different float valve Assyria but they seem to be a press in unit. I hate to ditch these carbs and replace with something I have to re tune
  2. Ordered it today, does that run same pressure with more flow?
  3. It is only a 4 mil cub with 65 bore. Running 35 LPG pump. But ordered 70 lph pump today. Fuel flow to carborator more than aduquit. So It seems the pump isn't it.
  4. I'm running 40 PWKs and at the end of a hill climb pass I end up going lean due to low bowl level. Fuel cap is modified, dual pingle, fuel pump, billet oversized bowls, power jets, floats are set high. The float valves appear to be non removable and I'm thinking this could be the weak link. Has anybody had any luck with modifying the float valve seat or needle?
