cocopot2002
Everything posted by cocopot2002
  1. Thanks guys I'll check it out. I was probly doing a little to much tugging.
  2. While trying to clean up the wiring harness mess under the gas tank by cutting away all the dangling clips from the old TORS system that was converted. I first removed the throttle switch and harness then I removed the clips that used to go to the carbs. Banshee wouldn't crank at this point. Unplugged the "brain" and bingo cranked right up. Went to remove the brain from the bike and cut off the 3 prong harness and wouldn't crank agin. Soldered the harness back onto the 2 wires I removed it from and still wouldn't crank. HELP..... Thanks
  3. I put a tors removal kit into my 99 banshee, tried to clean up the empty plugs by cutting them away from the harness, I must have done somthing wrong cause now it wont start.HELP. I unplugged the brain and it cranked so I took the brain out off and cut the plug from the harness and wont start agin
