katt68
Everything posted by katt68
  1. SUPER GLUE? seriously? will that work? what do you use?
  2. hey guys, i know ya all have been here and i am looking for the best solution. have a couple of head cover studs on my banshee that are stripped down in the cylinder head itself. they are an 8mm stud. what is the best fix for these? tap out to 10mm? fillthe hole in and re-drill and tap? suggestions?
  3. they were viton(brown) o rings
  4. i did not use a kit, i went to a hydraulic shop and fitted o rings that fit, i did use Viton ones(brown), what is the best way to see if the head is warped?
  5. the bike is bored out 1 size over, normal riding in Canada, nova scotia... running i belive 21 domes, new plugs, was working fine until recently started blowing the seals...i suspect the head warped? any way to tell? tors is removed.... was told to run 50:1 ratio of the amsoil sythetic oil..... please advise
  6. 99 banshee with a rhino cool head..keeps blowing the orings around the pistons.....ideas?
  7. thanks guys, anyone know where i can get parts in canada?
  8. can anyone tell me what head this is? what make /model? trying to order new o-ring set and need to know...thanks
  9. yeah, i am thinking that too, it has an aftermarket head on it but i do not know what make the head is. there are no markings on it. so, i wish i knew the proper o-rings to get...any ideas?
  10. My sons 99 Banshee is blowing the small rad hose that runs to the top right side of the radiator. The bike has been running fine. but after awhile the hose will pop off or burst spewing the coolant. Why am i getting a high pressure here? what is the problem? suggestions and ideas welcome.it does have a performace cool head on it....
