jadenrs03
jadenrs03's Achievements
  1. What kind of sander did you use or did you just sand it by hand?
  2. I'm new here and I just bought a 96 and the guy put a new clutch kit on it with hd springs and it was really hard to pull the shift lever in so I replaced the lever with a better one and lubed the cable that solved that problem but I had it out the other day and noticed that when I put it in gear it acts like it stalls even with the clutch pulled in and it lerches a lil when I have the clutch pulled in. Is this a sign that I have this same problem or could out be a simple adjustment?
  3. I just installed the yfz450 arms and shocks on my 96 after reading all this I am worried about the ball joints. Are you all saying the safest way to run this set up is with the yfz spindles?
