NA5TY
Everything posted by NA5TY
  1. axle, front and rear shocks, sold
  2. I'll check it out thanks man
  3. I have a few stock paarts that have been changed out for aftermarket. I am selling them so I can rebuild my raptor. The crank is shot.. All shipped prices as well All stock parts...an they are obo Cam 35$ Axle 165$ hell guards with foot pegs 60$ stock exhaust complete with heat shield 100$ rims 60$ shipped for 2 I have for 4 stock piston still looks pretty good 60$ sprockets like new 40$ front 14t an back 38t stock front shocks 50$ Stock rear shock 70$ lowering kit front an back 60$ stock grab bar 25$ all parts you are welcome to make offers on if interested in any send a pm i will send pics I am located in Bradshaw WV an only accept paypal..
  4. gas tank and hard ware sold
  5. Thumb Throttle sold
  6. Im looking to part out I bought it with a busted left side case an had a new side case put on it along with timing chain, wiseco 12:1 piston, new shims. Got to ride it for maybe a total of 20mins if that. Asking 1200 for the motor plus the ride(all info on motor above) will take pic of it with the head pulled an all around photo's of the motor (Will part motor for the right prices and offers) Make offers on motor If I get offers on the motor Ill part with everything... Will have pics of everthing tomorrow(make offers some are firm) Frame 09 Titled 500$ (black)Plastic has a few scratches with amr GFX includes Front , rear, bumper, and tank 300$ Seat 55$ Stock Exhaust(header with shield included) 60$ Air box with lid 50$ K&n Filter 30$ Front Shock 225$ Rear Shock with linkage 100$ Carb 160 need lower bowl though message ill explain Thumb Throttle with cable 40$ Tank with Pitcock 80$ add extra 10 for tusk gas cap (sold) Front A Arms top and bottom 130$ Steering Stem 65$ Hand Guards 15$ Front Breaks Calipers 45$ Front Bumper 40$ Head light 80$ Harness only 45$ Starter 60$ CDI 45$ Stator 110$ Heel Guards 30$ Nerf Bars does need a bracket on the left side 40$ Chain Guard 10$ Will get pics For all as needed Located in McDowell WV
  7. 2004 YFZ 450 Pretty well all stock except HMF exhaust uni airfilter As far as performance wise. But is needing a heli coil used on two of the cam bolt on the head. Good Bottom end motor can be checked head is pulled. location: West Virginia 2500$ or trade..
  8. Carbs sold to Ironman, intake boots still left 40 shipped
  9. had a few pms with offers will do either 200 shipped with out the carb boots , or will do 240 for everything
  10. will consider trades, 250 shipped
  11. ok went with ur advice on the jets , it is now opening up pretty smooth an is almost in sync but i think my left side is off still just a nudge what would make it sound like a pop can ting around the header pipe on the left side ??
  12. to be honest wasnt sure of it needed it after i think about it i know it dont now lol looks pretty though right
  13. Keihin 34mm Carbs Main Jet: 152 Pilot: 58 34 mm Carbs boots was used for a 5 min ride Pods are wore out though 350 shipped priority Shipping from West Virginia Priority Mail Any farther questions just PM me
  14. any idea's ?
  15. keihin.... flat side needle it dont look like the needle valve can be adjusted main jets size is a AB152 Piolet 58
  16. kk thanks for so many response's yea i should have checked b4 puttin on but I got in a hurry like something dumb.. Im located in West Virginia unsure what elevation that would be.. im running T5 Exhaust V force 3 reeds Cool Head with 20cc domes 34mm carbs pretty simple set up will check jet size and needle valve position tomorrow after work..
  17. they are sync'd at idle at 3,000 and i set both on 5,000
  18. I just put 34mm carbs on my banshee, I havnt checked the jet size or anything yet but.. when I open it up it does great threw the first 3 gears but 4th 5th and 6th when the powerband should kick in it kinda bogs and wont open all the way up any idea while or suggestions?
  19. Comes with 120 gb Hard Drive 1 controller All hook ups 210 Shipped
  20. parts and prices updated
  21. All prices are shipped prices, I use USPS... Shark Fin front tires with chrome rims 100$ New K&N Air filter 35$ Complete Front Brake assemble, has good pads off a 05... 75$ foot pegs Sold Trinity 2 for 1 intake for a single carb set up 30$ Clutch cover with new gasket on it, new water pump seal , with water pump, 35$ 6 new front a arm Bushings. 10$ toomey silencer pipes chrome 40$ Thumb throttle Sold Carb Cross over tube 10$ Rear master Cylinder Sold Have a few other things I will update..
  22. the new set of carbs came with a different needle unless there both warn
  23. I am running stock carbs, I have a previous set with the TORS on them that would always over flow eventually.. I bought the set now with out the TORS an they over flow as well.. I have cleaned them an yet they still seem to over flow.. how can I adjust the float so that it gets enough gas but dont over flow? Thanks
