Kybansheeman
Everything posted by Kybansheeman
  1. Its very boggy on take off, wont idle for long and i have the screws all the way for it to idle, bogs until it picks up rpm and powerband hits then it rips fine.
  2. When i got my shee, it had fmf fattys with powercore 2s, with a K&N filter. It was running 190 mains and had no power, i put 280 mains in it and now once u hit powerband it rips, but its very boggy until then and will foul plugs out once it gets hot. Any ideas? Thanks
  3. Thanks a lot, what about the air screw?
  4. 740ft, and 70 to 80 degress, thanks
  5. Any opinions? The guy was running 40:1 golden spectra, im gonna run the klots supertech
  6. Just got my banshee not too long ago, it was very boggy on low end, and was spiting oil out of the silencers like crazy, anyway iam cleaning the carbs, and it has 220 mains in it. motor is stock with fmf pipes and i run K&N filter with airbox. Thanks
  7. I need a stock air filter basket for a stock air filter, if you have one please send me a price, Thanks
  8. I pulled it out, but the spring is toast do i just need to order new springs?
  9. Ok, last night I went to clean my carbs. Tors is gone, so I unscrewed the caps and when I did the spring inside got caught and it spun and twisted it up, how do I get the cap off with out messing up the spring? Thanks
  10. I found a deal on some toomey silencers, ive always loved the look of them, will they bolt on my fattys? Thanks
  11. Alright Thanks, I found a deal for one on craigslist and thought I'd ask
  12. Will a yfz 450 axle work on a banshee? And the yfz 450 swingarm? Thanks
  13. Alright thanks man
  14. What do you use to put inside of the pipe connectors? mine are wore out and leak.
  15. Thanks guys, just wanted to make sure.
  16. My shee has the stock br8es plugs in it, well last weekend i fouled a plug and my buddy had a set of br9es plugs. i put them in and she ran better than before. is that a ok plug to run? will it hurt the motor in anyway? Thanks
  17. The tors is gone, no boxes on top, has a screw that sticks out about an inch on the side of the carb kinda a large screw. Also, it was running bad on the br8 plugs, I put a set of br9s in it and it runs a lot better. Is that ok? Thanks
  18. Im going to have alot of questions hope you all dont mind. But for idle adjustment, is that the screw on the side of the carbs?
  19. Its a 97, just has fmf pipes and silencers new top end. Thats all i know. Any vids on carb cleaning?
  20. Ok guys im new here, got my first banshee today, always rode yamahas still have my built 89 blaster. Its a 97 fmf pipes. Kinda sluggish in low rpm. any tips pointers anything to help. Thanks guys.
