kx450racer15
Everything posted by kx450racer15
  1. ok well i think i found a bad problem i was scared of i pulled the clutch basket off and it will free spin in neutral then started shifting thru gears with no clutch basket it will lock up in 1,2,3,4,and 6 5th free spins does this mean 5th is broken and i have pieces blocking all of the other gears or something?
  2. dont have any lol and i kinda need it fixed like tonight i just talked to a old banshee tech he siad there is 2 different washer one outside the basket and one in the center of the basket and the center hub. does anyone know the difference and witch one is suppossed to be in what location
  3. trans was full of fluid, yes pre soaked plates i just put springs fibers and steels in i got rid of the 1/4 gap but now the last plate is half in the basket and half out and when the clutch engages it can pop out it will roll in neutral but when you ut it in gear the clutch has zero effect thanks
  4. first and for most i would like to introduce myself my name is sean im new to this forum and would like to thank everyone for any info i have been around dirtbikes my whole life and just got a banshee and i think it has a major issue the third time we took it out while you released the clutch you would here a screetching noise while releasing the clutch. then it locked up and it wouldnt go into neutral and would not roll. I tore it apart the cltuch was fried, i ordered a new one and tired to install but something went south as of now i have about a 1/4 of slop in the basket with all of the fibers and steels installed any help would be greatly appriechiated
