I have a 99 shee that was a recovered theft.That sat around for a few years.
It was run without premix.
I honed the cylinders and replaced pistons and rings. The rings have an end gap of about .014"
Compression is only at 70 lbs, but the rings havent seated yet either.
If I prime the cylinders it does fire but won't run.
I found vacuum leaks at both reed valve blocks and added gaskets.
But It still won't start.
It doesn't draw in any fuel. I thought the 2 crank seals must have been beat up
so I replaced them also. No joy.
I injected low pressure air into one cylinder, and could see evidence of it in the second cylinder.
So at this point I must ask are the two cylinders isolated from one another like all the sleds I've worked on?
There no indication of a center seal or bearing in any of the part diagrams I'v looked at?
Opinions welcome......
