421venom
421venom's Achievements
  1. Ok i will get that checked out thankx alot guys
  2. But if that o ring is bad can antifreeze get to the oil? I thought they were separate cuz its transmission oil
  3. is the o ring inside? where the water pump is?
  4. Hey guys i need help...my shee was recently rebuilt and when i put the engine the bike ran great and i noticed a clicking sound coming from the crank case and today i did a oil change and antifreeze came out along with oil...what could cause this??? And can that do anithing with the clicking noise?? Any help is verry appreciated
  5. thanxx alot for the help guys ill call those guys from millenium see whats up
  6. yes thats what ima do,do you have any idea what they charge to do the plating?
  7. yeah
  8. those are the only sctratches, shown on the pictures
  9. what happens if i put new pistons with the cubs like that? one cylinder has small scratches inside the cylinder from where the piston broke, will that affect the compression??
  10. 421 cool heads, whats the difference??
  11. what do you mean??
  12. i just found out its a 68mm piston, whats a one bigger size??
  13. hey guys i need to bore out the cylinders on my banshee and i went to a machine shop but they said i need the pistons first but my question is how do i know what piston size i need and how do i measure them? this is the piston i have now..
  14. the jug just one side and will any piston fit if i bore it a next size?
  15. how can i fix it?
