It is impossible to read the plugs, it won't run long enough to change the color, they are still just black as could be from it's shitty idling and it doesn't matter what I do with the air screws the right side smokes like crazy and the left side almost none. OH and it has a boost bottle on it too, don't know if I mentioned that before. I tried some more pissing around with it today. There is no one around here who keeps stock of any of this stuff, it's all a week to 2 weeks away at least, then when it comes in it's the wrong f'n pilot jets anyways (so now I have 25's that are reamed out with a torch tip cleaner). I ordered jets, but in the mean time my 260's are exactly the same as a .052" drill bit, so i checked a .055 drill bit with some 280's I had that were from a sled and it was a little bigger, so I drilled them out to that thinking it would be around 300's and it runs way worse and still boils the rad, it won't even rev up now, spits and backfires. Before I could rip through the gears like mad then you get up to speed and let off a bit and that's when I loose throttle and starts blubbering and backfiring, no won't even rev up at all, I'm wondering if I'm too rich even at the 260's and have a cooling problem on top of it...........
