hey guys,
i own a 01 banshee and im having a lil trouble with it..i was wondering if u guys could give a lil help ..i think that i have done every thing possible and i havent been able to figure out the problem...my set up is the following: i have cpi inframe pipes , phat head cool heads , dfs dynatek ignition box and coil, a 200 wat stator with timing plate set 5 degrees, vforce 3 reeds with spacers, 2 into 1 trinity carb set up carb is 35mm bored to a 36mm ..compression is at 120 on both sides.i run it on 91 octane gas pump..castor 927 oil ,redone topend less than a year ago. i also replaced the crank bearings and all the seals. and this is the problem ; the bike starts of strong like a banshee should then after an hr one side stops working. if i change the plugs it comes back up again, but does the same thing within the hr...ive checked the plugs and they are black and wet.i have tried switching the coil wires to see if it does it to the other side and it doesnt do it. it stays on the same side.one thing that ive have tried is that i lift the cap on the side that is not working while the bike is one and thats wen i can see the spark and only then the bad side starts to hit.but when i snap the cap back on it stops working..any feedback will be highly appriciated.i hope u guys can help thanks for ur times...
