Hpibajajumper
Everything posted by Hpibajajumper
  1. For the oregon riding rules having an atv that is only made for one person you can only have 1 person on it. even if they are very young and even with a helmet they can't do it at all with out a big fine. If it was an atv built for 2 people that is excluded from the rule but the kid would have to be behind you while you ride. YOu can only legaly have 1 person on an atv built for 1 person. 2 if the atv is a 2 up machine you can have 2 people on it. but with next years rules you cant have a side by side on any atv trails any more like we use to. they will have there own trails and will be able to share the orv trails. Sucks since i dont have enough suspension travel to navigate the orv triails near me.
  2. I have done alot of research but i cant seem to find any drag frames for a banshee. right now it is stock but that wont last long. looking a a cheetah heads with some other things but not sure yet. i want a drag frame but i can seem to find any. can any one help me.
  3. What should the compression be at? i am looking at a used banshee that has 125 psi in the left cylinder and 128 in the right cylinder. is this good or bad
  4. i have been playing for a while. it is very fun but i hate when magnum ammo is used against me.
  5. i am looking at a used banshee and it has cut front fenders and have been trying to find factory un cut fenders. but i am not having any luck with my search. Does any body know where to get factory front fenders for a 1992 yamaha banshee.
  6. Cool i was thinking of sand star front and rear tires since i have a set for my yamaha warrior. i will ask the db question in the exhaust section and see if i can get a number.
  7. I have a bone stock 2004 banshee and i am currently set up for dirt running. i want to run in the sand but i dont plan on doing a sand only machine. i want to be able to run dirt then to play in the sand just bolt on sand tires and go. What size paddles should i get? I might plan on getting a bore kit later. For the sand should i run with the stock front tires or get sand ribs for it? I also need to know what the db level is on the stock exhaust if possible.
