99twinshee
99twinshee's Achievements
  1. Thanks....its fixed!!
  2. Hey guy thanks for the reply......its my quad were talking about.....these are the things that ive checked....wasnt bad gas....CDI good......ignition good.....stator tested good has spark...removed tors wiring....it has spark and fuel...compression check by thumb...choke tube on no cracks...carbs are cleaned....timing plate tight....flywheel tight...even shot starter fluid in cylinders...any help is greaty appreciated!! I'm going to do a real compression test tonight just so i can see the numbers on the cylinders
