calcium12
Everything posted by calcium12
  1. How do you replace the seal/gasket thingy that the shitfer rod goes through
  2. ye i did that but it was all rusted and it wasnt pushing down so i think i have to buy an new one from someone
  3. master cylinder
  4. my banshee is only firing on the left cylinder at 1/4 throttle i pulled the plugs out and they were black...what could this suggest in addition to that, how do you rebuild a rear brake pump ?
  5. omg ....so im reving it right....and when it hold it steady at like 1/4 throttle, only the left pipe smokes, then i let go, then the right pipe backfires a bit and it goes back to idle then both of them start smoking eventually also it seems there is a hissing sound ...im not sure if this is normal or not, could this be a possible engine leak ?
  6. i did i sprayed the shit out of the holes and what not with brake cleaner....like i used the whole bottle but one thing i noticed was i was adjusting the levels of the carbs (cause they were uneven) with the idle screw....could this have something to do with it because one wasnt going down all the way (to where i wanted it to be) so i had to raise the other one...idk if this has anything to do with it
  7. yo so it starts like a boss now but it wont rev...like i can rev it a bit then it sorta stops at that point and declines....the tors on my banshee are removed so idk what this is ?
  8. how do i unclog that ? and where is that located ?
  9. good news i got it to fire for a bit ...but i spreayed gas in the carbs through the air filter ...so it quickly burned that up and died....also it was only smoking from the right side any ideas?
  10. are you trying to get me to shock myself....i know there is spark cause i already did shock myself holding the metal
  11. my 1999 banshee wont start still....im pretty sure it has spark and the gas is going to the engine i came across a voltage meter how should i use it ? i dont even know why its no starting
  12. i took them off...and just unscrewed the big thingy (idk what its called) but that is all, yes the hose inbetween the two carbs is connected ...how do i check the floats ?
  13. gas is new, like i would say maybe couple weeks old ? we just use it for the weed wackers and blowers and such so we dont go through it that fast i mixed it 32:1 approx
  14. OMG i jus check the spark again....and i shocked myself so there is defiantly spark but one thing i noticed was that the threads of the spark-plug looked to be moist is that normal ?
  15. i sanded it down even more, i check spark and it is there, and there is gas going to it (im pretty sure, cause i pulled off the line and there was gass and put it back on) .... so there is gas and spark idk what to do now what else does it need ?
  16. I sandpapered most of the paint off the contact point, still doesn't start. There is only 1 ground point right ? the one in the back ??
  17. I have recently put back together my 1999 banshee that i bought with a crooked frame, it ran with the old frame i have recently replaced it. I have added all the necessary liquids and turned all the buttons on, but when i kick to start it nothing happens. Could this be an electrical problem, I am pretty sure that the TORS are removed. Also on another note i painted the frame before putting it on, could this affect the ground ?
