Brownie
Everything posted by Brownie
  1. Sold on ebay awhile ago sorry...no one wanted them on here
  2. Yes they are complete.
  3. I ran a set for awhile had good mid range power, didn't have the to end pull like r2 s or cpi.
  4. I have a set of lrd pipes, that are no longer adjustable that I'd like to sell. I'm looking to get 80 out of them plus shipping pm me of your interested or want pictures.
  5. Sounds like the same problem I'm having, try checking your stator and all your wiring.
  6. Month..I also run it in my banshee along with 3 of my cousins
  7. Last time I got oil for my sled techniplate was 32 dollars a gallon. His number is 1 763 479 2478 or email at [email protected].
  8. If your interested in getting some give me a shout and I'll give you a number to a guy that's a dealer for it, I know he ships everywhere.
  9. I guess I don't see where the possibility of water getting in the gasket is there with all bolts.
  10. I have a 2001 banshee new rebuild,.40 over stock ports, I'm using vitos super stock pistons, my carbs have been rebuilt, floats adjusted to book spec, I'm running stock carbs tors removed, I'm running lrd pipes with a toomey two to one air filter, 290 main with 25 pilots. My problem I'm having is, the thing only sparks on the third kick or so, and when its running its only out of one cylinder. There is smoke coming out of both pipes but more on one side than other, the only way it sorta runs like a banshee is wide open. I tried a new coil and it did the same thing, would only spark every few kicks. You can feel when it sparks because it chugs forward. Any help would be appreciated! Thanks Dustin
  11. You didn't put new reeds on it did you?? If so did you put them back wards on the reed cage?
  12. Brownie
    Tap for idols
    Not a .75 pitch tap
  13. Brownie
    Tap for idols
    I lost the tap for my idols. The tap that is 6mm by .75 pitch. Can anyone help me out?
  14. Brownie
    Stock carbs
    I have rebuilt a few times and still leaks gas.
  15. Brownie
    Stock carbs
    As it says, I think mine are junk.
  16. OK THAT WORKS FOR ME, COULD YOU POSSIBLY SEND A PICTURE TO MY CELL PHONE? ILL GIVE YOU ADDRESS LATER TODAY! THANKS
