werd671
werd671's Achievements
  1. I finaly checked the compression I got 105 psi for both and thats after 4 kicks each. when i removed the plugs they were saturated with oil and gas. I am very new to working on atvs, i was told you have to remove the engine from the frame and split the case to replace the crank seal on the right side. is this true? could I have maybe f*cked up the seal I put in previously causing my smoke problem?
  2. the only thing I've done to it was replace the crankshaft seal, oil, and sparkplugs.
  3. did you get this problem fixed and what was the cause? just picked up a banshee and i am having the same problem. i swapped the coil wires and changed out the plugs but the problem is still on the right side. i also have light brown and white smoke whe i give gas on idle and acceleration.
