2003bansheefmf
    2003 banshee with fmf pipes and v force reeds.
2003bansheefmf's Achievements
  1. Yea im very sure that it isnt losing coolant and yes i have had it in the water but not much but i was wondering if my billit dipstick is leaking around the seal but its brand new
  2. Im thinking its to lean on low end
  3. Ok my banshee has water in the oil when i drained it and i checked the radiator and reservoir and it did not move a drop the antifreeze was good . So i put new oil in it then checked it 2 days later after riding and it still is milky so i just drained it again and checked the wntifreeze and it was still all full what is wrong why is it getting milky but no antifreeze missing.
  4. Ok my banshee has water in the oil when i drained it and i checked the radiator and reservoir and it did not move a drop the antifreeze was good . So i put new oil in it then checked it 2 days later after riding and it still is milky so i just drained it again and checked the wntifreeze and it was still all full what is wrong why is it getting milky but no antifreeze missing.
  5. the float level is the same as left side but did not check the reeds and it does bacfire occasianly
  6. ok i let someone ride my banshee and they loaded it bad and got on it to clear it out and was only running on one cylinder so i figured i fouled a plug so i went to the store got two new plugs and same thing swaped the coils over and same thing, but when i turn the gas off while riding it begins to fire and run fine until it runs out of gas, but the compression is good. so itook the carbs apart and cleaned them good and checked the right float and it floats put it back together and same thing need HELP.
  7. ok my 2003 banshee leaks gas ou of both carb overflow tubes if taken them off sevaeral time cleaning them to see if i fixed it or not and there seems to be no problems with the floats and needle and seed what is wrong?
  8. i bought the banshee in summer and it ran fine and now it backfires and bougs down and gas leaks out of the carb over flow tube possibly float stuck or is the tors messing it up hears the mods, fmf pipes, and k&n airfilter pretty much stock. dont know what jets it has.
  9. banshee is backfiring
  10. banshee is backfiring what is wrong?
