Timz
Everything posted by Timz
  1. what about your air screws and clip location on your needles? also where do you usally ride?
  2. hi everyone i need help on jeting this thing in. it is a 99 shee .60 over pistons. drilled air box, k&n cone no lid, +4 timing, t5 pipes, f&f silencers, reed spacer. no tors. i live in waterford,mi right now it has 30 pilot, 330 main, 2nd clip on needle, air screws 2 turns out. it's way off super rich, what should i do? any help greatly aprciated.
  3. ok. i'm new at this so how do i go about doing this?
  4. same mains and jets, plugs look the same. what do you mean by synced?
  5. jets and all are all new. pilots 30 mains 330 needles on second clip. i rather it be rich than lean but its not really that rich.
  6. im intrested in grill if you seperate
  7. ok i have a fresh rebuilt banshee, new crank, .60 over, fresh jeting, the thing that worry's me is when its running smoke is only coming out one pipe is that ok or is there a problem? and if there is a problem how do i fix it, btw seems like the same presure is coming out both pipes but only one is smoking.
  8. seats were worn, fixed now, thanks guys
  9. ok, thanks alot i will check it out and report back
  10. i'm new to this banshee. it runs fine and all but as soon as you turn the gas on the overflow off of the carbs leak. what is causeing this and how do i go about fixing it?
  11. bought it ported. by the looks of it it may not even be ported might just have had the castings cleaned up? i havent ran it yet still puting it togather, i live right by lakes though.
  12. thanks for the input
  13. the highst main and pilot? i was thinking maybe a 27.5 pilot and a 330 main or is this way off?
  14. what i have is a 2001 banshee bored .60 over w/ viti's superstock pistons, weisco crank, full t5 setup, trail ported cylinders, k&n pro flow adapeter w/ no lid just have cone filter and box. stock carbs. -4 timing just doing trail riding, i live in waterford, michigan, i have the full vito's jeting kit. what jets should i use? any help would be great.
  15. sent paypal, thanks builder. please close up thread found part, thanks
  16. i'm looking for a used cheap trans, broken gears fine. i just need the rear shaft the one with the sproket, dont care about the gears just need the shaft to be stright. e-mail me at [email protected] or pm me on here, thanks. just need the rear trans shaft the one that has chain sproket, has to be stright.
  17. do ou have title's for both frames?
  18. will you sell just the blue plastic over the radiator w/the grill in it? if so how much?
  19. what color is the grill?
  20. hi guys, i'm looking to buy a A arm banshee frame w/ clean title, perfer in the michigan area so i could pick up. e-mail me me at [email protected] if you have one. thanks,
  21. bought a arms great deal and fast shipping. thanks again.
  22. i'm looking for a set of orange plastics not cut for a banshee, blue tank cover, ignition w/ a key, a good clutch basket with no groves, and a crank in like new conditiion w/no slop and good bearings ect.. please e-mail me with what you got at [email protected] thanks,
  23. i have black carbon fiber set i'd trade..
  24. can you send close up pics of the fingers to [email protected] ? also is there any groves in it at all?
