dantheman
Everything posted by dantheman
  1. I'm at sea level,I live in los Angeles,ride in dumont and pismo mostly,while we were at pismo we threw in my buddies pwk35s on meth to check if it was the tunning that was causing this prob..we knew he's 35s are dialed in...bike ran awesome...thanks for all the help guys at this point I'm leaning towards my pilots...
  2. Yes lock up,override,,,what pilot are you running? Also where do u ride?
  3. Cel middle clip. Anyone else run similar set ups in dumont, glamis,,??
  4. I will check my needle position asap,just wanted to know if I was in the ball park with my jets,I will definitely buy some new jets tho...
  5. Leak down test passed,my builder recommend my current jetting, stage two port on cylinders..thanks for the info..
  6. I need some help jetting my 4mill cub,just came back from pismo and wasn't to happy..I have a hesitation when I launch at the drags,almost as if it wants to die off for a second or two, but then it gets going pretty good.it also hesitates to shift gear just for that gear.after that it gets it through all gears...I have read a lot of info on jetting but don't have much experience,my question is what circuit may need attention if not all? What are u guys running for Ur jets on pwk39... My set up is 421 cub 21cc domes 4 mill crank pwk39 on vp110 at sea level..shears oof..current jetting 167mains and 67pilots not sure on the needle position ,bike idles good and rides fine except when i launch?? I know that when banshees are not tuned right the shifting can also b weird. I beleave that's what's confusing me,would that b the mains since I'm at wot?even though my speed hasn't picked up? Any info would b great , thanks in advance
  7. John at sandtoyz unlimited..hands down..
  8. I got a +5 swing ARM for sale.comes with Regina chain shock dogbone chain guides everything to bolt on except carrier..300...located in norwalk Ca..will send pic upon request..
  9. R.I.s. has all there porting work done by k&t...not gonna lie I looked into them and whent else where because of there price.I also don't think there that experienced in performance ..
