possum
    6
Everything posted by possum
  1. Relooked at the pics. Man there was like NO penetration. it looks like it just slid out of that bracket. How far in was the peg into the bracket?
  2. That design is the main problem here. the square sotted joints and the way its fit up. Thats a no-no. Its easy to not get full penetration that way. But a qualified welder would know that before welding. Also yes it needs to be welded all the way around. Thats just not right.
  3. To try and answer you're question, it doesnt look like a banshee arm. The shock location looks to be 3-4" closer the the pivot tube then it should be. unless it was intended to improve the angle. But in turn needing a shorter strut or marvin. I wouldnt have done it that way. Also the front pivot dont look offset like a banshee is suppossed to be. And i really cant see the chrome one good enough. Also take some measurements. Just so you know a stock location is 12-1/4" from hooking the tape in front of the pivot tube to center of shock mount hole. To be able to run a link.
  4. its gonna be around 11" but the only way is to put the arm on and measure, as special06 said.
  5. what is the length of shifter
  6. i got 100 + I see you're 12 pack and raise it to a 18 pack haha
  7. those are factory. And that assembly is what im talking about I swap from carb to carb. sudco does not show it. but they come off and interchange.
  8. 4mil for sure. id go with his aggressive dune port. kevin has a port with timings around 194 128. Ask him about it.
  9. everybody has blue white or silver. do somethin different.
  10. remimds me of tylers just uglier.. haha
  11. I like the blue seat with all blue platics n frame. all smurfed out.
  12. Sniper
  13. Replace the whole tube assembly. It has the star type bolts on it with orings underneath. Quick and easy when you have parts carbs. Ive done it several times, it works.
  14. You need alot more then one nut per arm. Thats prob around 5-6 grams each arm
  15. No I didnt have to.
  16. every noob thinks they have a drag ported serval.
  17. Keihins can be switched back. Ive done it.
  18. out of 4 sets of shearers I put on bikes they NEVER hit the outerwears.
  19. Dont post in here if you dont want to buy. So STFU and GTFO. via JUAN
  20. ive seen 1 rudy kurtz cylinder in my hand and it was far from impressive and in ran average. Not saying yours is.
  21. Wow
