03 Banshee LE
Everything posted by 03 Banshee LE
alright thanks alot everybody for all the advice i believe the snowmobile studs is gonna be my best way to go.
oh yeah i meant to ask that even with these huge snowmobile studs can i still get sideways and do donuts and stuff just playin around?
Alright everyone thanks for all the advice I think I'm gonna go with the snowmobile studs
alright thanks but what kind of setup is on the back of that black and red shee it looks like it would work really good?
what would be the best kind of tires to stud for ice and where would i get the supplies i live in ky and the subdivision i live in gets ice and snow on the road and nobody clears it i just want somethin to mess around on 4 of 5 times out of the year...not looking to spend much just something safe to use.
Bills Pipes with different silencers
03 Banshee LE replied to 03 Banshee LE's topic in Jetting & Exhaust Forum
no i like the bills pipes i want to keep them im just wondering what kind of silencers would match up i found some toomeys cheap somebody just let me know what diameter my head pipes are or something i need some quick my stock silencers sound horrible. -
i already have bills headpipes with factory silencers and i was wondering if any banshee silencers such as pro circuit fmf toomey or something would fit the head pipes?
i need a black front fender or laker custom front fender in good condition...just let me know what you have im also trying to find some itp ss alloy wheels to trade for my douglas wheels that are in good condition...let me know what you got im open to all offers and in desperate need of the front plastic i have stock yellow front plastic if you want to swap..
Black Powder Coated Parts
03 Banshee LE replied to PACIFIC NW BANSHEE's topic in For Sale - Parts & Accessories
Footpegs $35 shipped? -
Banshee Starting Problems
03 Banshee LE replied to 03 Banshee LE's topic in Banshee Repairs and Mods
well this is great i just somehow broke the throttle cable...im just gonna take it to my old mechanic that worked on my hondas and yamahas before i just dont have the know or tools to do it maybe he can show me a few tricks because i just cant figure this shee out. -
ok i hooked up the choke tube and nothing now what? haha i cant figure this thing out...my first banshee and it looks like im gonnaa have to spend money on a professional but anymore thoughts on what it could be i would love to save some money and do it myself.... -
is it like a t tube with a big long tube coming from the tank or just one small straight piece of tube between the carbs? -
i thought about that but how do you check it? -
ok i cleaned the carbs and replaced the plugs and it still wont start. i dont know what it could be. it was starting and running fine then i drained the oil where the clutch is and adjusted my clutch then tried to start it and it still wont start but i did mess the clutch up because after i put everything back together it wont go into gear it just clicks so im wondering why it wont start is that because it cant find neutral or something it rolls no matter if i shift up or down so i cant really tell if its in neutral so would it fix it if i fixed the clutch and gears and then tried starting it is that my problem? -
ok thanks i figured it was something like that i was gonna clean the carbs this week but one more question...do i need to actually take the jets out? and then clean the carbs -
yeah everything is hooked up read my newest post its more accurate
my banshee will start but only after about 20 kicks and it has more smoke coming out of the left exhaust than right and the pressure is greater on the left and it wont idle with the choke all the way in or all the way out it has to be halfway and after it warms it will start after no less than 2 or 3 kicks. Should i just try cleaning the carbs first.
i just took the left carb off to get the push lever assembly that cable hooks to out bc it was messed up and you could just pull it out with your fingers and then i hooked the left carb up and checked both and they are getting fuel and i just now got back in went to try to start it one more time and it fired up for about 30 seconds and there was alot of smoke out of the left exhaust and none on the right one what could that mean?
could i just use spray carb cleaner then hook it back up?
no i didnt turn it over on its side i just jacked up the whole bike to eye level to make it easier to work on and then lowered and tried to start it with no results.
its not really a hose just like a rubber connection with a hose clamp on it like a rubber boot or something and what is the best way to clean carbs this is my first carb machine as well ive always had fuel injection.
i replaced my clutches and fixed my push rod assembly and all i did was disconnect the hose from my carb to my exhaust and the little hose that goes between the carbs and then i hooked every thing back up and put all the clutches in and oil and now my bike absolutely will not start i kicked consistantly for almost an hour with the throttle open closed and choke in all positions with fuel off, on, and reserve and it still won't start and when i put it in gear it still rolls like its in neutral and what could i have done wrong this is my first banshee so i really have no clue about two strokes period.
where can i find a free banshee repair manual download? i know there has to be one somewhere i found one for my honda
ok i figured out how to route it now i need to know where i can get the spring that the clip is on?
No i was in the garage messin with the clutch and adjusting the handlebars when it popped off and no pieces came off I was just wondering how it should be hooked back up....
