tgriffin27
1 Follower
About tgriffin27
  • Birthday 06/04/1973
    Horneytown,North Carolina
    2006 Banshee Special Edition, FMF Gold Series Fatty Exhaust, ITP Holeshot Front Tires, ITP Rear Mud Tires, Moose Handlebars and Boost Bottle, K&N Air Filters
Recent Profile Visitors
1,842 profile views
tgriffin27's Achievements
  1. I sold my banshee and have a case of this left. I used it in my banshee's transmission. I am asking $9.00 a quart, I paid 11 dollars a quart off amsoil's website. Message me and I can figure out what shipping will be to you. PRODUCT DESCRIPTION AMSOIL Formula 4-Stroke® PowerSports Synthetic Motor Oil (AFF) is specially formulated for ATVs, UTVs, snowmobiles and other power sports applications. Its broad viscosity range and WAX-FREE formulation make it excellent for use in both hot and cold temperature extremes. As an SAE 40 weight motor oil, AMSOIL AFF provides outstanding protection for hot operating engines, while its 0W rating and -60°F pour point ensure easy cranking, excellent cold weather starting and quick post-startup protection. Formula 4-Stroke® Power Sports is an extreme temperature lubricant that provides outstanding performance in high performance, recreational or work/utility engines. Resists Heat and Thermal Breakdown AMSOIL engineered Formula 4-Stroke® PowerSports Synthetic Motor Oil to withstand the high temperatures of recreational engines. It effectively resists oxidation and oil vaporization to prevent carbon/varnish formation, control oil consumption and minimize exhaust emissions. AMSOIL AFF controls oil thickening for good fuel economy, and it keeps engines clean for peak operating efficiency. Excellent For Transmissions AMSOIL Formula 4-Stroke® PowerSports Oil is Wet Clutch Compatible and contains no friction modifiers, making it ideal for both two- and four-stroke ATV transmissions. The friction modifier-free formulation is designed to prevent clutch slippage, delivering maximum torque and power to the wheels – a critical feature for towing or high-horsepower engines. AMSOIL AFF meets the frictional requirements of JASO MA/MA2. Superior Wear Protection AMSOIL AFF is formulated with high levels of anti-wear additives that provide excellent protection for pistons, bearings and gears in transmission containing units, while its shear stable, SAE 40 viscosity delivers a thick lubricating film for an extra margin of protection in hard working engines. Anti-Foam Churning occurs in high RPM engines that can cause oil to foam, depleting its lubricating abilities and increasing heat and wear. AMSOIL AFF controls foam, promoting cooler engine operation and reduced wear. Special Additives AMSOIL Formula 4-Stroke® PowerSports Synthetic Motor Oil contains robust dispersant/detergent additives that effectively neutralize the high levels of acids and combustion by-products prone to small engines. And it is Anti-Rust Fortified for superior rust prevention, which is especially important in seasonally or infrequently used power sports equipment. Applications and Recommendations AMSOIL Formula 4-Stroke® PowerSports Synthetic Motor Oil is recommended for four-stroke engines and transmissions on two- or four-stroke powered applications. It is an all climate/all season oil that replaces 0W-30, 0W-40, 5W-30, 10W-30 and 10W-40 oils for ATVs, UTVs, snowmobiles and other power sports equipment. Also recommended as a replacement for Polaris Synthetic PS-4 Plus and Arctic Cat Synthetic ACX. Manufacturers include Polaris®, Honda®, Yamaha®, Ski-Doo®, Can-Am® (Bombardier®), Suzuki®, Kawasaki® and Arctic Cat®. • API SL/CF, SJ, SH, SG • JASO MA/MA2 • ISO-L-EMA2 Compatibility AMSOIL Formula 4-Stroke® PowerSports is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL motor oils. Service Life Follow the equipment manufacturer’s recommended drain intervals. TYPICAL TECHNICAL PROPERTIES AMSOIL FORMULA 4-STROKE® POWER SPORTS SYNTHETIC MOTOR OIL SAE 0W-40 (AFF) Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 14.7 Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 83.7 Viscosity Index (ASTM D-2270) 184 CCS Viscosity, cP @ (-35°C) (ASTM D-5293) 6139 Flash Point °C (°F) (ASTM D-92) 226 (439) Pour Point °C (°F) (ASTM D-97) -51 (-60) Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 7.3% Four Ball Wear Test (ASTM D-4172B: 40 kg, 75°C, 1200 rpm, 1 hour), Scar, mm 0.35 Total Base Number 10.5
  2. I can always use two sets how much are yours with shipping to Kernersville NC 27284?
  3. Yall are going to miss a great time the weather is perfect here at my house. Cloudy so you dont get sunburned and its not too hot and not too cold. It's Just Right Saturday and the weather is awesome no rain just clouds and it is soo warm!! Great Riding Weather
  4. Thanks for the advice I haven't ridden my banshee that much I haven't even bought gas for it yet since I bought it. I don't know how fast they go threw fuel. Depending on the weather friday I may go back home and not camp out. I only live three hours away from busco.
  5. I will be there sometime friday depending on when my Brake Rotor Lock shows up I ordered. I am only bringing 5 gallons of fuel I hope thats going to be enough. Luckily I can run pump gas so might have to go buy more.
  6. I dont know what color you call it but my yfz450 is powdercoated green.
  7. If he doesnt take them all I could use the Front piece "race cut"
  8. ok Who is She and Where Can I Go To See More Pictures?????
  9. Need some stock ones with good rubber inserts. Mine are long gone and the PO just bolted them back together and my left pipe has a hole from rubbing the cylinder head.
  10. Fast Shipper and great guy to deal with.
  11. I may be interested I would really like to have a lonestar but a durablue would work for now. What is your asking price and how long has it been used?
  12. How much for the bumper shipped to Kernersville North Carolina 27284 ?
  13. I new it sounded too good to be true
  14. Saw this today and thought someone out there may want it. Has a ton of new stuff on it so I thought it was well worth the $2,200 price tag. If i had the money it would be at my house right now. Do you guys think it's worth the asking price? http://charlotte.craigslist.org/mcy/2305119070.html
