01blackshee
01blackshee's Achievements
  1. Thumb throttles suck faaaat whale cock!!!!
  2. x2 maybe if you were running domes under 20cc but ur not so ur good to go!!!
  3. Might wanna take ur cylinders to get checked out.. might need a new bore job!! But you cant go wrong with wiseco!!
  4. Toomey reccommends for the needles to be on the 4th setting.. and to use STOCK 25 pilots.. and depending on ur elevation on the main jet. they reccommend a 280 main from sea level up to 2500ft higher elevation they reccommend bigger jets.. I installed 27.5s and it ran like shit.... as locogoat stated above. every bike is different..!! Jus need to figure out what works best with your bike.. http://www.toomey.com/html/t5-inst.htm.... check this page out.. i did what they said and it runs like a champ now!!
  5. Finally got the Shee runnig after a long 8 months.. time to break her in!!!!
  6. Problem solved... Toomey reccomends the needles to be set on the 4th groove.. one carb was set at the 2nd groove and the other at the 1st groove.. previous owner was a dumbdick!!! Got her all sorted out.. i just need to idle her down a little bit.. Thanx for the help to the fellas above!!!
  7. I just fired her up and let it run for around 5 mins.. and both plugs fouled out!! So im confident its running to rich.. Now i just need to purchase a jet kit.. any recommendations??
  8. Stock carbs.. with TORS still on.. temperature is in and around freezing about now is below freezing. im in new jersey.. ratio is 32:1 with yamalube.. and its equal amount of smoke from each exhaust!!... Im pretty sure the jetting is all messed up.. Just want some other opinions... Ima going to take the carbs apart to see what my needles are at and what my pilots are..
  9. Hey fellas... i just did a new top end rebuild... before i did this rebuild the bike had ported cylinders and a Cool Head w 17ccdomes... I no longer have the ported cylinder or the cool head! The main jet was 340.. I went back to a stock cylinder @ 64.25mm bore and a stock head!! I changed the main jet to 270!! but i did not change the needle or pilot jet..( I dont even know where the pilot jet is) So that would help!!! Im at a little over 100ft above elevation.. I have t-5's v 3's, and i have a pro design air filter kit and i run with the lid off. My shee fires right up. and idles fine, but smoke is pouring outta the exhaust.. and I place my hand over the tips and i get a black oily residue onmy hand . Im assuming im running too rich.. Please imnot an idiot its just my first banshee rebuild.. Im not trying to ruin anything. im being very cautious here!! So i would like to know if the oil residue is from me running to rich.. remember i didnt change my carb needles or the pilot jet.. I was hoping someone can give me an idea of what i need to run.. I would do the sticky of what jets to run.. but i dont know what pilot jets or needle ii am running.. I must to retarded bc i dont know where the pilot jet is!! if anyone can please help out a newbie its appreciated.. I dont need a buncha people telling me im an idiot and etc.. I just dont know the nature of the beast yet!! any help would be greatly appreciated!!! I also tried the shout box to avoid a post. but noone responded!! So this is my last resort!!! THANX AGAIN
  10. BHQ musta kicked me or booted me.. bc my user name and email was not found.. o well instead of 2001blackshee ill settle for 01blackshee
