Holeshot
Everything posted by Holeshot
  1. Ok i will give it a try i just didn't know if i would damage anything on the inside using a impact gun .. thanx again
  2. Iam trying to remove my front sprocket and put a 13 tooth on it , The problem is i can not remove the large nut i bent back the lock washer i have the chain on and i have someone holding the rear break on still i can not loosen the dang thing . Does anyone have a better idea ? Could i use a pneumatic gun ?
  3. Ok we was messing with it a bit today and if we turn the pilot air screws out to 41/2 turns it makes it better but not like it should be . Then we moved the clips on the main jetts to the richest position and put the pilot air screws back to 2 turns out and it still is the same. Not what it should be but better then when we first started . Does anyone have anymore input on this ?
  4. ok i pulled the plugs and they are both clean left side is like a tan color and the right side is like a gray . no build up on them . air filter is clean .
  5. Ok heres the deal i just got back from a rip and it will bog till it hits the power ban ( every gear ). It idles fine and starts fine cold or hot . both pipes get hot and i didn't get a chance yet to pull the plugs ( too hot ouch ) . does this sound like a jett problem still . does anyone live near Hazelton PA that knows what there doing maybe mess with the jetts for me ? 570-751-3024 plz no sex calls ...lol Thanx
  6. oops 18 mm domes ^^ noob ....soz
  7. Its not low compression starts fine cold . This thing was set up for racing it runs race fuel in it has 18 cc domes not that it makes a diffrence or maybe it does . I have run 2 strokes back when i was a kid but that was a while ago . i will check the things that have been suggested and i will give you my out come . Thanx for the reply .
  8. Iam not sure i posted this in the right area if not i apologize . Ok heres my problem , when i goose it in first gear it bogs/hesitates for a split second then i can rip through every gear full throttle. What could be the problem here . I just got this banshee and iam new to the fourms any help would be appreciated. Thanx
