I hate to see some good thinking slide into oblivion, so I will throw in.
THE358BANSH, your numbers look good to me on your cut dome. I drew it as a solid model in solidworks and came up with pretty close numbers.
120mm radius with .160 from the peak. 18.399 grams and a volume of .413 ci. .413 x 16.387 = 6.767 cc
I am sure there is a variance in dome profile from your piston to my drawing that would explain the minor differing in values.
This dome has a weird radius but I drew it to compare numbers. I plugged in the exact dimensions from your drawing.
.495 ci = 8.11 cc
So my question is: what values are you guys shooting for in compression and squish velocity? Are you setting a standard at static? Do you do a comparison to what you think is happening at different RPM ranges?
Seems to me there would be drastic changes in both compression and squish velocity as the rod/crank/piston stretch at different RPMs. The pistons just start to leave marks on the combustion chamber on my RD400 at 10,000 RPM with squish at .02.
