RabidRacing
    2001 Flat track/tt banshee
RabidRacing's Achievements
  1. Never heard of a "plug chop" but very interested, i know some about reading plugs, as far as white being too lean, wet being to rich, and so forth...
  2. I put the jet kit in and set the needle on the 4th groove, per toomey instructions, took it out to a wide open field so i could get some seat time, at first it wouldn't run at all, i pulled the lid off the air filter box and it runs awesome, actually it screams! i have been reading on here and alot of people say get rid of the lid, i have a k & n with an outerwear, i just can't believe that the lid makes that much of a difference, makes me wonder if my tune is still off?
  3. Elevation where i'm at is 890 i believe. I did a compression check and i'm hitting 120psi per cylinder, spark plugs have some white on the tips which should be accurate considering i'm running stock jets with aftermarket pipes, my jet kit will be here wednesday, overall i think out of all the banshees i looked at i think i picked a good one, it has been taken care of, and it was worth the 300 mile round trip picking it up.
  4. I can't find anything when i search top end kits, first thing i'm going to do is perform a compression check and see where im at, then i will do a tear down and check bore sizes, but as far as what kit to buy, i have always run the wiseco pistons and never had any problems, like i said, i searched and can't find any comments or reviews on top end kits.
  5. Ya thats kind of what im thinking, i would rather do it now then wait till it really goes bad, just not sure what direction i want to go, nothing to radical, just freshen it up, i would like to go with the CNC head but i still need to do some researching on dome sizes and how different sizes effect what and such. Thanks for the welcomes, this site has been very helpful to me so far, and owning a banshee is like owning a corvette, everyone looks out for eachother and helps one another.
  6. After searching around and doing some reading i finally did it, i bought my 1st banshee! Its a 1989, still has the stock bore! It has Toomey T5 pipes and silencers with a K&N Airfilter, New douglas blue label wheels with holeshots all the way around, RPM rear axle and i think it's 2" wider with the spacers i have in it now. The carbs haven't been jetted so i ordered the Toomey perfect jet kit and im missing exhaust clamps, so i'm looking at getting the cascade clamps. It starts and runs, probably will run better when i get it jetted right, it's had yamalube 2r oil in it mixed at 32:1, after doing some searching i see that oil is pretty much a personal preference, i think i would like to run the klotz 50r, but not sure if i should stay at 32:1 or go 40:1. My 1st major modification will getting ahold of stellar and have some 2 + 1 J arms made, and yzf shocks.
  7. lol ok i will keep looking.
  8. I'm looking at buying a 2002 banshee with CPI in frame pipes, cool head 18cc domes, dune/drag port, 35mm kehein carbs and clutch lockout. Here is my question, the carbs were setup for alcohol and said it ran great, but he tried to switch them to gas and didn't get all the pieces to switch them back over so its out of tune and not running right? Can anyone give me there opinion on this before i buy? Would it be best to leave it setup to run on alcohol? Is it even possible to convert from alcohol to gas? Any advice would be very helpful. Thanks
