desertshee
desertshee's Achievements
  1. i do have the tube between the carbs and the slides went back into the same carb because i only took one apart at a time for that reason. when i push started it and took it for a test ride it ran great. it just wont idle or start cold would it make a difference if i moved the needle richer
  2. yes i started all the way in and turned them almost all the way out. before i put the reeds in the bike ran perfect
  3. elevation is 1000' phoenix, az the bike was setup by ALBA this is from there website * Main Jet 300 * Pilot Jet 32.5 * Alba needle @ 4th clip * Air screw 1 1/2 (approx) turns * Remove air box lid
  4. 2001 banshee I just put new chariot reed cages with boyesen reeds and now i cant get my bike to start cold without starting fluid. As soon as it starts the first time it will start every time on the first kick but it wont idle. Here a list of mods FMF fattys Pro flow with K&N filter lid off Boost bottle stock carb 310 main 32.5 pilot 1 turn out The ran perfectly fine before I put the new reeds in. can anyone give me advise or put me in the right direction
